Getting Started with Micro Dot pHAT
This tutorial will show you how to install the Micro Dot pHAT Python library, and then walk through its functionality, finishing with an example of how to use Micro Dot pHAT as a clock.
If you haven't already, then follow our guide on how to assemble and solder your Micro Dot pHAT.
As with most of our boards, we've created a really quick and easy one-line-installer to get your Micro Dot pHAT set up. We'd suggest that you use this method to install the Micro Dot pHAT software.
curl https://get.pimoroni.com/microdotphat | bash
Once that's done, it probably a good idea to reboot your Pi to let the changes propagate.
Using the software
Lighting individual pixels
We'll begin by looking at the set_pixel function from the Python library. This
function lets you set the state of individual pixels. Note that you can't
individually control the brightness of each pixel, only the brightness of all of
the pixels at once.
Type the following in your Python prompt to import the functions and variables we'll need to light some pixels:
from microdotphat import set_pixel, clear, show, WIDTH, HEIGHT
Before we start, we'll clear any pixels that may already have been set.
clear()
The pixels on Micro Dot pHAT are numbered from the top left hand corner of
display 1 and, as is the convention in Python, are numbered from 0. So, the top
left pixel of display 1 is 0, 0.
We'll light the top left pixel first.
set_pixel(0, 0, 1)
The first two arguments passed to the set_pixel function are the x and y
(row and column) coordinates of the pixel we want to light, and the third, 1
tells the function that we want to switch the pixel on rather than off.
You'll probably notice that... nothing has happened. That's because we need to
call the show function to push the changes we've set onto the displays.
show()
You should now see the top left hand pixel of the first display lit.
We'll now clear the displays and call show again to push the changes to the
displays.
clear()
show()
We're going to extend this now to the whole of the first column on the first
display. The library includes WIDTH and HEIGHT variables that define the
width and height of all six displays.
If you print(WIDTH, HEIGHT), you'll see that it will tell you that the
displays are 45 pixels wide by 7 pixels high. Why not 30 pixels wide (5x6)?
Because of the spacing of the displays, to make text and animations display correctly across the displays, we've added some imaginary pixels between the displays (3 between each) to make things look sensible.
This means that the top left pixel of display 2 is 0, 8 rather than 0, 5.
We're going to use the HEIGHT variable to light all of the pixels in the
first column of display 1.
for y in range(HEIGHT):
set_pixel(0, y, 1)
show()
All of the pixels in the first column should now be lit.
You've now seen how to light individual pixels and we could, in theory, use this method to light all of the pixels across all of the displays, but there is a function that makes lighting all of the pixels a whole lot easier.
Lighting all of the pixels
Before we start this section, we'll clear the displays and import what we need.
from microdotphat import fill, clear, show, WIDTH, HEIGHT
clear()
show()
Lighting all of the pixels is as simple as calling the fill function, making
sure to pass 1 in, to tell it to switch the pixels on rather than off, and
then calling show again to propagate the change.
fill(1)
show()
Taking this slightly further, if you wanted to flash all of the pixels on and off, you could do the following:
clear()
fill(1)
show()
time.sleep(0.2)
clear()
show()
time.sleep(0.2)
We use the time.sleep function to introduce a small delay of 0.2 seconds each
time the displays are either filled or cleared, and wrap the whole thing in a
while True loop to keep it running continuously.
Now that we've seen how to control the pixels, we'll move on to displaying text and scrolling it.
Displaying and scrolling text
The Micro Dot pHAT library has a convenient write_string function, that can be
passed a string which is passed into the buffer to be displayed on the matrices.
Depending on how long your string is, i.e. if it's longer than six characters,
you may want to scroll it across the displays so that all of it can be read.
We'll look now at an example of how to write a string into the buffer and then scroll it across the displays.
from microdotphat import write_string, scroll, clear, show
clear()
write_string('YARR!! ')
scroll()
show()
time.sleep(0.05)
We've added a bit of empty padding to the end of our string, to make it more
legible, and you'll notice that we've put the scroll() inside a while True
loop, to keep it scrolling constantly.
Each time you call the scroll function, it will shift one place through the
buffer, and therefore give the impression of scrolling the text from right to
left.
Because we only have six characters in our string, we probably don't need to scroll it constantly. Try the following to just write the string and then display it static-ly:
clear()
write_string('YARR!!')
show()
You'll notice that it's awkward to read this text when it's not scrolling. For
situations like this, where you have six or fewer characters (assuming you have
all six displays installed), we've added an option that you can pass to
write_string that specifies how to space the letters, also known as kerning.
Try the following to write one character of our YARR!! string to each of the
six displays:
clear()
write_string('YARR!!', kerning=False)
show()
You should now see one character displayed on each matrix.
Clock example
Finally, we'll look at a simple little example of how you can use your Micro Dot pHAT as a retro clock. This example is included with the Python library, but we'll break down what the code does here to help you understand how it all works.
Here's all of the code:
import datetime
from microdotphat import write_string, set_decimal, clear, show
clear()
t = datetime.datetime.now()
if t.second % 2 == 0:
set_decimal(2, 1)
set_decimal(4, 1)
set_decimal(2, 0)
set_decimal(4, 0)
write_string(t.strftime('%H%M%S'), kerning=False)
show()
time.sleep(0.05)
First, we import the libraries and functions that we'll be using elsewhere in our code.
import datetime
We need the time library again to introduce a small delay between each
iteration of the while True loop that will run all of our code.
The datetime library will allow us to grab the wall clock time and then
reformat it into the specific format we need: the two digits each from the hour,
minutes and seconds.
And we need several functions from our microdotphat library: write_string,
set_decimal, clear, and show. set_decimal allows us to control the
decimal points on the bottom left of each display, which will act as separators
and also blink on and off each second.
We're going to wrap everything in a while True: loop to keep it running until
we exit the program with control-c.
clear()
set_decimal(2, 1)
set_decimal(4, 1)
set_decimal(2, 0)
set_decimal(4, 0)
show()
time.sleep(0.05)
Let's break down what all that does.
First, we clear the existing data in the buffer ready for the new data going
in. Then, we grab the time and assign it to a variable t with
t = datetime.datetime.now().
Our t datetime object has lots of methods associated with it, two of which we'll
use here. The first is the second method, and it returns exactly what you
might expect, the current seconds value, as an integer. The second is the
strftime method, which is an incredibly useful way of reformatting the
datetime object into whichever format we'd like.
We have an if and else that check whether the current number of seconds is
divisible by 2, if t.second % 2 == 0:, and if it is then it sets the decimal
points between the hours and minutes, and the minutes and seconds on:
set_decimal(2, 1) and set_decimal(4, 1). The else catches oddly numbered
seconds and sets the decimal points off accordingly.
Then, we write our formatted time string to the buffer with
write_string(t.strftime('%H%M%S'), kerning=False). '%H%M%S' tells strftime
to return just the digits of the hour, minutes and seconds, in 24-hour format,
e.g. 141500 for 2.15pm. We use kerning=False to display one digit on each of
the six displays.
Finally, we call show() to push the buffer out onto the displays, and add a
small delay of 50 milliseconds with time.sleep(0.05) to give sufficient
resolution to our clock without running it an unnecessary number of times each
second (at 50 milliseconds delay, it will run around 20 times each second).
That's all for this getting started guide, but why not use what you've learned to think up a fun new use for your Micro Dot pHAT?
Perhaps a Twitter ticker? Or a tiny game of snake or pong? Or a weather display, combined with our Enviro pHAT board? Or a really low resolution screen to play movies on? (probably not that last one...)
